Muggydude
12.01.2010, 07:06 PM
I personally wouldn't get the plastic. Spur. I really haven't seen or heard anyone have problems with it as long as you set your mesh right. Also, make sure you get offset rims for tires. Much more stable. Also, you might want to try to pick up some white springs, 45 weight oil, and use those with the large tube for the shocks. Much better than stock for bashing and jumping. Make sure you zip tie the front and rear bumper braces together so the hinge pins don't fall out. Last thing, fing a thicker, longer screw and replace the front bumper screws with them (drill out the holes) the stock ones are very weak and will break.
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
