el tomaso
12.02.2010, 03:54 PM
LRP buggy in da house Got it yesterday, but didn't start building because I would have to clean/tidy my workbench first. I have my own system, that most people would call a mess Today, after some thought, I just made the kitchen into workbench number two
Starting build now, I will post pics when it starts to look like a car.
Hope my RCM stuff comes before I finish the build...
Thomas G
Shark413
Shark413's Avatar
12.18.2010, 10:28 PM
Here is my Z-Car with the mech brakes hooked up. Its a little hard to see but I am running a brake servo just behind the ESC. Because the Z-Car runs the rear brake on the rear diff the motor has plenty of clearence.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Shark413
Shark413's Avatar
12.18.2010, 10:30 PM
Here is a better shot of the mech brakes.
el tomaso
12.19.2010, 09:25 AM
Hey, my build has come to the electrics install. I have three motors to choose from, maybe you can help me. I have castle's 1800kv motors, in 1518 AND 1512 size. Then, I have a NEU 1509 2400kv....
I have a 4s 3300mah 35C battery to use for a ultra-lightweight setup with the 1509 and modded mamba max/MMPro. This was to go in my Hyper Mini STe, but I suddenly wanted to try it in the LRP buggy.
What is the weight of the LRP/Z-car in relation to other 1/8 buggies. Is it among the lightest, or not?
Of course the castle 1518 with 6s and MMM would be VERY much fun BUT it will make it harder to find room for the mec brakes, and I am going to use them.
What would you guys recomend? Thanks.
TG
Shark413
Shark413's Avatar
12.19.2010, 04:12 PM
I sold my first Z-Car (the one pictured above) but I am putting togther a second one. In my first buggy I ran a 1512 but it gets really hot here in the summer and heat was always an issue. So I switched to a bigger 1515 motor and it ran cool. For my second Z-Car buggy I am going to try the 1512 again (on 4s) and maybe a 1509 on 3s. On my first Z-Car I had the brake servo mounted on an extended center diff mount top plate (along with the esc) so it was completely out of the way of the battery/motor. I think I may run this buggy without the mech brakes and go with a lighter setup using the 1509 on 3s. I also have a Losi 8ight 2.0 and Hot Bodies D8 (both Tekno brushless conversions) and both run big motors (1515) and mech brakes and I want to compare them to a lighter buggy (Z-Car) using motor brakes for comparison.
el tomaso
01.04.2011, 01:24 PM
I ended up with MMPro and castle/neu 1512 1800kv, on 5s with mec brakes front and rear. I am going to try the 1518 too, just not at first
The mount and tray is RCM, and I have moved the rear brace over to the left side with some modding, this way I have no problems with small pinions. I am using the springs from a hyper 8,5 PRO with the ofna upper spring retainer over the stock spring cup(or what its name is), as adviced in this thread. Much better damping/spring ratio IMO.
If the snow will melt and evaporate, maybe one day I can drive this car too
Here are some low quality pics(long overdue, sorry), of the car almost finished. The wiring will be dealt with, I assure you
That is my little schnauser drinking in the background
Thomas G
el tomaso
02.18.2011, 09:48 AM
The snow finally melted, and I got to try my new LRP buggy on a football-field with short astroturf. It was just amazing, I loved the way it drove, lots of steering on and of power, which I like. I got about 15mins out of the 5s 30C 3200mah battery, which is just fine IMO.
When LVC hit the temps were all under 100f, perfect.
Only problem so far, the centre diff is leaking badly from the hole that has a set screw to seal it. I can guess all three diffs must be rebuilt with silicone/glue to seal the threads of the set-screw. Not fun, but had I read up before the build I'd never have this problem. Its well known.
Thomas G
