josh9mille
josh9mille's Avatar
12.02.2010, 07:58 PM
Originally Posted by Darren View Post
Had it out today in the snow, and it suddenly started cogging, really badly. To the point where you almost need to stay on full throttle to avoid it. Batteries are fine (Using the standard packs), sometimes the steering servo -when turned slowly and not moving the truck- doesn't respond until you give a bit of throttle, even a single 'cog' to send some power through the truck. I tried changing the CH1 position on the reciever and the problem remains. I also re-linked the Tx/Rx, still the same problem.
Here is a video of what happens when I put two 6 cell packs in series and try to run the truck:
http://www.youtube.com/watch?v=Xt0y8Cx8lQM
Any thoughts?
It almost sounds like there is a pebble in the gears or something
Darren
12.02.2010, 08:38 PM
Originally Posted by Dj_Sparky View Post
Try disconnecting the servo, try another receiver and radio, and go over the wires to make sure its all connected tight and right.
Checked everything just now, everything's connected fine. Tried disconnecting the servo and still had the same problem.
I don't think there is, everything's sealed and if you put it on a single 6 cell pack, the wheels will spin consistantly as long as you give it 60%+ throttle.
I'm starting to think that the ESC is at fault and I should just return it to get replaced under warranty? Also the front bulkheads have a few 'holes' in them. Like there has been bubbles in the plastic moulds , interesting.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.03.2010, 12:38 AM
I had a "hole" in my front bulk too. I figured out what it was for though, just before I sold it I had to replace the front diff. There is a long screw that you access through that hole after you pull the suspension pin out
Darren
12.03.2010, 12:27 PM
Aah, that makes sense.
On the plus-side. I tried the revo again this morning, and its fine .
