sikeston34m
sikeston34m's Avatar
12.04.2010, 01:21 PM
Uh Oh!
OK, next step I would do is:
Remove the lower skid plate. <----part that protect the tranny on the bottom
Then I would disconnect the front and rear driveshafts from the tranny
This will help you figure out what's locking up.
If the tranny input shaft turns freely, then it's not the tranny.
It could be one of the diffs.
I hope this helps you figure out what the problem is.
First, I would check for a rock stuck in one of the wheels or A-arms. I've had this happen before too.
Good Luck!
