thzero
12.05.2010, 01:02 PM
Why'd you go with the 5T axles instead of just using the XL axles? Seems like the latter might have been a cheaper option. Then again, the XL axles a prone to break where the threads begin; was that the issue?
Originally Posted by LiqrSicc View Post
That setup is gonna be nice! So far my BP diffs are holding up. I have the 1717 too but the 1520 works out so good I don't have the need to use the 1717. I couldnt resist the sales either!
LiqrSicc
LiqrSicc's Avatar
12.05.2010, 03:39 PM
The whole idea was to get away from the threaded axles and to use axles that actually used fit a buggy/truggy 17mm adapters. Not to mention the XL drive cups use the smaller dog bones compared to the Flux
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
thzero
12.05.2010, 04:13 PM
Well, that would be incorrect. The XL and Flux both use the same drive cups and suspension dogbones. The XL axles are just longer by about .5" inches. :)
LiqrSicc
LiqrSicc's Avatar
12.05.2010, 04:26 PM
Yeah you're right. Either way it still has the threaded ends which I really did not want. The only solutions were the 5T axles or the Integy adapters. Both of which I have... the 5T axles just feel a lot beefier than the Integy adapters on the stock axles.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
toplakd
12.05.2010, 04:28 PM
I have also one XL set of diffs with cups and the flux dogbones do not fit as they are bigger.
Dejan
I removed my signature.
thzero
12.05.2010, 04:38 PM
Im sorry but you are wrong, they do fit. The XL and Flux drive cups are 11mm for the 11mm balls on the dogbones.
Flux Dogbone part #: 86246
XL Dogbone part #: 86246
Flux Drive Cup part #: 86248
XL Drive Cup part #: 86248
Flux Axle: 86928
XL Axle: 86249
I've got two XLs and one Flux. Just saying. And LiqrSicc you should check out my 5T conversion for what i did with the XL axles and the Baja 5B hexes; granted they wont work for your application, but you could do something similiar with the ofna hex adapters if you cant source 5T axles.
Dejan
