simplechamp
simplechamp's Avatar
12.17.2010, 04:14 AM
You are right, they aren't resting at 3.0V/cell, I have the cutoff set there but by the time I get home and charge them up they have rebound to probably 3.2-3.3V/cell. But that would actually imply the capacity is even higher. Anyway, they definitely hold their rated capacity and then some!
So in this case the packs might be underrated, but packs can be properly rated or overrated too. That is why you rely on voltage to determine a full charge, and not rated capacity.
