01.02.2011, 07:09 PM
He has the KD unit in his savage. Counting the teeth on the 2 internal gears will give all the info we need.
RC-NUT
RC-NUT's Avatar
01.02.2011, 09:39 PM
Oh cool.
motor pinion: 22T
Savage spur: 49T
Internal pinion: 18T
Internal spur: 45T
Flux F+R diffs
Thanks guys.
RC-NUT
RC-NUT's Avatar
01.02.2011, 09:47 PM
And fixing the outdrive cups falling off should be pretty easy. Mark where the set screws contact with the output shaft, then drill small dimples for the set screws to engage. Use red loctite and let it dry overnight before use
I'll have to give that a shot. I've tried smoothing the flat spot with a dremel as well as blue and green thread lock. I was affraid of the red loctite once I needed to remove it. I have really cranked the 2.5mm set screws too. It's amazing how fast they slip off. I wanted to try drilling a thru hole on the shaft and using an HPI set screw pin but I was affraid of weakening the shaft.
Thanks for the tip.
01.02.2011, 10:17 PM
Originally Posted by RC-NUT View Post
Oh cool.
motor pinion: 22T
Savage spur: 49T
Internal spur: 45T
Flux F+R diffs
Thanks guys.
2.5 internal ratio for the KD unit.
So with that info, and looking at your pics you appear to have some 40 series road hawgs, which are around 6" in diameter. I did not factor any tire ballooning into this, but here is about what you should be doing.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 2.5
Other Ratio: 1
Spur Tooth Count: 49
Pinion Tooth Count: 22
Total Voltage: 22.2
Motor KV: 1580
Tire Diameter (inches): 6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.23 : 1
Total Ratio: 18.41783 : 1
Tire Circumference (inches): 18.85 inches (478.78 mm)
Rollout: 1.02:1
Total Motor Speed: 35076 RPM
Vehicle Speed: 33.99 mph (54.61 km/h)
Effective KV Value: 1580
34 mph is a bit slow... The std gearing in the flux tranny is a bit higher at 2.2:1, and that would give you around 40mph. Still not loading that 1717 at all. Plus the flux tranny is sealed, allowing the use of oil for lubrication, and it must be stronger due to all metal gears. The std flux mount will not fit the 1717 but a simple angle mount would, or have a clamp style made up, and clearance the tvp.
I did not have this issue as the 1717 fit my TDR mount in the lst just fine. Just another reason the lst is king...
Thanks for the tip.
The hpi set screw with the pin is not really a good idea, IMO... Make a dimple and use red loctite, you can always get the screws back out with some heat from a lighter, heat gun, etc.
Knez
Knez's Avatar
01.03.2011, 10:07 AM
I think GCM is working on some FLUX tranny...should be worth waiting ;)
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
RC-NUT
RC-NUT's Avatar
01.03.2011, 10:20 AM
Thanks for running those calculations. I also picked up a 25T pinion just in case so I'll try both.
Who knows maybe I'll try the 1717 in the Muggy and put the 1518 back in the savage.
