01.02.2011, 10:17 PM
Originally Posted by RC-NUT View Post
Oh cool.
motor pinion: 22T
Savage spur: 49T
Internal pinion: 18T
Internal spur: 45T
Flux F+R diffs
Thanks guys.
2.5 internal ratio for the KD unit.
So with that info, and looking at your pics you appear to have some 40 series road hawgs, which are around 6" in diameter. I did not factor any tire ballooning into this, but here is about what you should be doing.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 2.5
Other Ratio: 1
Spur Tooth Count: 49
Pinion Tooth Count: 22
Total Voltage: 22.2
Motor KV: 1580
Tire Diameter (inches): 6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.23 : 1
Total Ratio: 18.41783 : 1
Tire Circumference (inches): 18.85 inches (478.78 mm)
Rollout: 1.02:1
Total Motor Speed: 35076 RPM
Vehicle Speed: 33.99 mph (54.61 km/h)
Effective KV Value: 1580
34 mph is a bit slow... The std gearing in the flux tranny is a bit higher at 2.2:1, and that would give you around 40mph. Still not loading that 1717 at all. Plus the flux tranny is sealed, allowing the use of oil for lubrication, and it must be stronger due to all metal gears. The std flux mount will not fit the 1717 but a simple angle mount would, or have a clamp style made up, and clearance the tvp.
I did not have this issue as the 1717 fit my TDR mount in the lst just fine. Just another reason the lst is king...
I'll have to give that a shot. I've tried smoothing the flat spot with a dremel as well as blue and green thread lock. I was affraid of the red loctite once I needed to remove it. I have really cranked the 2.5mm set screws too. It's amazing how fast they slip off. I wanted to try drilling a thru hole on the shaft and using an HPI set screw pin but I was affraid of weakening the shaft.
Thanks for the tip.
The hpi set screw with the pin is not really a good idea, IMO... Make a dimple and use red loctite, you can always get the screws back out with some heat from a lighter, heat gun, etc.
