simplechamp
simplechamp's Avatar
01.09.2011, 05:43 PM
Do I need a certain angle or anything? Or are metric flatheads a standard angle on the head?
EDIT: Wikipedia says "Countersink cutters are manufactured with six common angles, which are 60°, 82°, 90°, 100°, 110°, or 120°, with the two most common of those being 82° and 90°. Countersunk-head screws that follow the Unified Thread Standard very often have an 82° angle, and screws that follow the ISO standard very often have a 90° angle."
So which do I need?
PBO
RC-Unobtainium
PBO's Avatar
01.09.2011, 06:45 PM
So which do I need?
Well, do you now the CSK angle of the screw head? that would be the answer
I wouldn't worry too much about pressure angles unless the tensile load is extreme. If you want to be certain, bed the screws in with epoxy - this will allow mirrored pressure angles
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
