Thomas Porfert
Thomas Porfert's Avatar
01.10.2011, 01:19 AM
Originally Posted by padrino View Post
Patrick,
Are you currently offering the 8mm bullets used with the XL kit? I don't see them on the site so I thought I would check to see if they will be coming soon? I wanted them for my batteries to make sure the connectors aren't a bottle neck, if they aren't available yet what do you recommend? Thanks
8mm bullets should be available very shortly; MAP will be approximately $7.60 for 3 male and 3 female. Arct1k is right, 6.5mm will handle the current just fine. The biggest challenge is getting the 8 gauge battery wire soldered to the 6.5mm bullets; it's quite a tight fit and some shaving is generally required.
Thomas Porfert
Tech Support
BIG-block
01.10.2011, 06:53 AM
I was just wondering. I know Patrick said that you wont be able to use the MMMXL HV on 12S with motor brakes but what about if the MMMXL HV was to be used in a 1/8th on-road application with a really low KV motor? Possible or would I still be limited to 10S?????
