DrKnow65
DrKnow65's Avatar
01.18.2011, 09:37 PM
I think it was a problem with the internal BEC, the way it shut down and started up again was just like the CC BEC did when I had the Savox servo go bad.
I'd turn then the car would shut off, then rearm and be good till I turned again.
I just can't remember if I heard it rearm, or just start moving again... I think it was quick enough that it didn't go through a start up cycle.
3 runs, and I kept the data from all 3. It was looking awesome! And I had intended to start ramping it down today to make it more track manageable.
Knez
Knez's Avatar
01.18.2011, 10:00 PM
So the first one is well done...sorry to "hear" and see that. Good is that everything else is OK!
Well i guess it happens to best to...i had like 5x MMM V3 burned on 6S.. but support was more than great... so i never complain over CC, just hope this ESC can handle 6S as i am buying one in 12h (as here is night time) :)
Just in case i will use CC Bec Pro, maybe u should consider about one!?
Q: Does mamba xl comes with 6,5mm bullets already soldered on the wires?
Got 1520 waiting..
EDITED: Why didnt CC put together Mamba XL and Bec Pro or stronger Bec than it is at the moment?
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
