simplechamp
simplechamp's Avatar
01.31.2011, 04:55 PM
Originally Posted by wallot View Post
slipperential does not fit my D8 as it is too short . I tried it :) and it requires hacking the top diff brace.
why clutch? to get some drive train protection. slipperential is also 40grams heavier than standard center diff.
so you think that MMpro bec set to 7.2V can handle two high power servos?
Use an external BEC like the CC BEC. The MMP BEC can only go up to 7V, and tends to have trouble with amp-hungry high torque servos.
How many grams of rotating mass will a clutch system add?
Couldn't you raise up the center diff top plate with some spacers/washers to make room for the Slipperential?
