Go Back   RC-Monster Forums > Support Forums > Team Tekin
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.31.2011, 08:42 PM
To reach 65 you will definitely be needing 6s to keep your amp draw lower. A CC/Neu 1515 1y 2200kv motor would be a good choice, for that mattet the Mamba Monster 2200 combo is prolly your best bet. It's one of the most reliable setups out there and one of the cheaper setups you can run short of going with hobbyking stuff that won't have squat for a warranty. This combo has pushed ~15Lb Monster Trucks to 60+ Keep in mind though with gearing for those speeds your going to need to stick to smooth surfaces, stay out of the grass. Driving through grass puts a ton of extra load on a setup and is an easy way to burn something up if you don't have the right setup
