jagboy
jagboy's Avatar
03.13.2006, 09:38 PM
Hmmm... good to know. But what about nimh? They definately dont stay at 1.2v /cell. Say halfway through the pack they measure 1.1v. If the BEC is putting out 6 and the Rx pack 5.5, wouldnt that stress the BEC current too? It obviously wouldn't be bad for the batteries. The alkalines were in fine shape when I took them out, so I'm guessing they weren't damaged. O well... I'm done w/ this problem. I'm sending it off to Mike ASAP. I am sick of having a many multi hundred dollar savage sitting on my desk w/o an ESC.
JB
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.14.2006, 11:25 PM
It is true that you can use a receiver pack in addition to the BEC according to the instructions. The instructions ALSO state that the bec is only rated for 12 cells. So...if you have over 12 cells, you shouldn't technically be using the controller's BEC at all(with or without "assistance"). Under 12 cells, and you can use a receiver pack for "help". It really only makes sense to run a receiver pack AND the controller's BEC when using 6 or 7 cells. 18 cells using the controller's BEC is asking for it, as the controllers BEC unit must "dupmp off" the extra voltage(20+ volts input vbs. 5.5volt output = 15+ volts worth of extra energy to dissipate) as heat.
