02.07.2011, 07:02 PM
Mocked it up some more. Cut the upper arm as described. The hole behind the pivot ball hole is alomst 4mm, used a 4mm drill bit by hand to open it up. Cut the shaded are off and rounded it, fits very nice.
In the pic I have a spare lst hinge pin acting as a turnbukle. I have ordered the hellfire m5x60 turnbuckles and will swap them out when they arrive.
1st pic shows the lower arm attached to the bulkhead as it is on a stock savage, 2nd shows the spacing on the other end of the arm.
1st pic shows the savage lower arm connected to the lst2 hub, 2nd is a close up of the spacing between the stock hingepin brace and the stock arm. Measured it is right at 10mm. This gives enough clearance in the diff output cup for some negative camber to be dialed in via the upper arm turnbuckle.
So I will pull off one of the braces, trace it on some al stock I have and add 10mm to each side.
I also measured the width difference and I should end up with more than 1/2" extra width per side. Probablt 15mm or more, and that was just eyeballing it with a ruler. The hingepin brace will add 10mm per side, and the longer cvd axle and hub design add about 5mm. I may even widen the hingepin brace so that the hingepins will clear the center bulkhead area so that the bulks will not need to be modified at all.
Now for some issues I have noticed. Since the upper arm will be longer than the lower arm the truck will experince positive camber as the suspension is compressed. Not good. I am working on an idea to fix this. Best thing I have come up with is to make a spacer block that mounts to the top of the c hub thru the hincepin hole and effectively moves the hingepin pivot closer to the bulk, so that the upper arm can be shortened to the same length as the lower arm. Bur we will cross that bridge when we come to it. Right now I would like to get it working as show.
Positives:
No mods to lower arm.
Minimal mods to c hub, cheap part
Minimal mods to upper arm, cheap part
Addl parts inexpensive.
Better axle, stronger, cvd type allow for better steering throw(will also require mods)
Larger inner bearing, wider bearing spacing, possibility of 3rd added bearing in hub
Stock lst2 rear hubs will eliminate rear tierods
wider stance without using axle extenders
Use of std hex adapter from 1/8 scale buggy/truggy
and I am sure there is more stuff I am not thinking about.
