E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.11.2011, 01:05 AM
BrianG's speed calculator is a great tool for this. A 2000kv motor on 4s is going to make it hard to gear for that kind of speed. 58/24 gearing will get you about 45MPH but I don't know if that gearing will actually fit and work. Generally on 4s a top speed of 40MPH is your best bet, after that your going to be stressing your batteries and esc and maybe the motor. How close is your 54/18 to meshing? I would try using the pinion you have and get a 56 or 58 spur and see how that works for you, spurs are cheap, pinions are not. Good luck getting it figured out.
Just my 2 cents here now. Try gearing for about 35 and see how you like that. Personally I have always geared my monster trucks down and had more fun with them. Currently I have a Savage Flux, came geared 44/20, I'm now running 49/17 and have a 52 spur on the way to run 52/15 and possibly drop down to 52/12
Speed calculator
http://scriptasylum.com/rc_speed/index.html
steveo
02.11.2011, 11:42 PM
thanks yeah i'll try a different spur its pretty close a few teeth should get it, i'll shoot for 35-40 then, this one might see a little track action
steveo
02.14.2011, 12:22 AM
was able to make the gearing work 54/18 but speed was only 25mph i have new hyperion batts, its got racing tires maybe a hair taller than stock, i recalibrated the esc to tx, , i contacted the seller to see if he changed any tranny gear , the truck was acting as a summit when he had it not the case. then i thought my motor is not a 2000kv but it rips in my 3906 e-maxx with 70/18 geared i dont think the motor is less than 2000kv, somrthing is not adding up
