brainanator
brainanator's Avatar
02.12.2011, 12:48 PM
What are the rods running next to your shocks? Some kind of sway bar set up?
Never seen something set up like that.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.12.2011, 01:20 PM
It's explained in the OP, try reading ?
Very clever getting the out runner in there
Looks VERY nice, excellent job !
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.12.2011, 01:28 PM
Thanks Bondo. The transmission input shaft was pretty long and 5mm in diameter which is what gave me the idea for the outrunner. It turned out to be too short so I replaced it with this one- http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLBL8 It was a drop in fit.
Suspension travel limiters. It's mainly to limit the ground clearance. They do work like sway bars to a degree because when you go into a turn the wheels to the inside of the turn don't extend when the weight comes off of them. This phenomenon is commonly referred to as "body roll".
