Semi Pro
Semi Pro's Avatar
02.19.2011, 10:59 PM
You did not touch on balancing your tires, this is the 1st mod you should do to any rc, period. I did my own testing with balancing and taping with a set of badlands and maximizer beadlocks. The difference was amazing, I picked up speed, the straight line and turning stability was greatly improved, I can imagine bearing wear was greatly diminished, and it just made driving the vehicle so much nicer. Plus temps went down on the motor esc and batteries. All you need is a cheap prop blanancer, some sticky tire weights, and a hot glue gun. Maybe I should do a writeup. I can balance a set in less than 10mins.
agreed! ballanceing is a must, tires last so much longer and come unglued much less often when in ballance
Balancing Tires
JasonB
Flux Fan
Balancing Tires - 02.19.2011, 11:16 PM
No reason to re-invent the wheel. Click Here
02.19.2011, 11:32 PM
Interesting vid, but he does not cover cleaning the tire bead prior to assembly or cleaning/scuffing the wheel either. The mold release agents used on the wheels and tires can be thick and will compromise the ability of the glue to bond correctly.
Squirrel is not the authority on this stuff, that has been proven before on this forum.
Also, the "putty" he recomends is not the best stuff to use to balance a MT tire, or bigger. You will be using a ton of it, and it comes off easier.
Looks like I really need to make a vid. I can see the "Pimp does RC" video series being a big hit!
JasonB
Flux Fan
02.19.2011, 11:43 PM
Looking forward to your tutorial linc!
mothman
02.20.2011, 01:03 AM
Linc, so what is the best putty money can buy? really interested to try this tire balancing.
