Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
03.05.2011, 12:08 AM
I've been thinking the same thing. IIRC, it uses 14mm hexes, so that's one thing that'll have to be changed (to use 12mm hexes). Aside from that, the only possible roadblock I can think of is to make sure the axle carrier unit will fit inside the wheel hub.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
03.05.2011, 08:17 AM
The 12mm plastic hubs have a 5mm hole, can be drilled out to 6mm easy enough. The front spindle/carrier is pretty big so a 2.2/3.0 SC type wheels will be needed or a full off set 2.2 like for the Hyper TT .
