777 truggy
virusss
virusss's Avatar
777 truggy - 03.14.2006, 08:44 AM
Hallo my friends i have a problem with my buggy MP 777,I wanted to mount wheel from monster (HPI NUBZ)but they touch against pulling of the steering,for you what tires an wheel I must use in order to transform in truggy mine 777?
Thanks boys:032:
Dafni
Dafni's Avatar
03.14.2006, 09:19 AM
There are some wideners around. Even Proline makes a widener, and it converts your 19mm to 23mm hex. Check the PL site.
Or, if you can find a way to make your buggy hexes 14mm, you could try some offset maxx wheels. But I would go for the PL wideners
virusss
virusss's Avatar
03.14.2006, 09:28 AM
Thanks dafni, what is the difference of "offset wheel" to standard wheel?
And what body mount i can use?
Dafni
Dafni's Avatar
03.14.2006, 09:45 AM
Offset wheels are "deeper". They make your truck wider. And more stable. But they take away a bit of steering response.
Don't know about body mount, sorry.
virusss
virusss's Avatar
03.14.2006, 09:51 AM
ah ok i understand, thanks very much :)
squeeforever
squeeforever's Avatar
03.14.2006, 06:30 PM
i would be weary of the adapters like those because they will put ALOT of preasure on the bearings and will cause bearing failure.
Sylvester
Sylvester's Avatar
03.14.2006, 06:52 PM
Yea, what squee said, and with that in mind, id try the LIGHTEST tire/wheel combination to try to keep power robbing friction to a less.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.14.2006, 11:30 PM
I carry maximizer adapters that allow maxx sized wheels on the 1/8 buggies. They seem to be pretty good, but any widener like this does put additional stress on the bearings.
MetalMan
MetalMan's Avatar
03.14.2006, 11:57 PM
I have bought some Imex Romulin wheels that use standard Maxx-size tires, and are offset with a 17mm hex. These have been used on my 1/8 buggy, and work great (but would work better if I only had a 10t pinion!)
virusss
virusss's Avatar
03.15.2006, 02:43 AM
Thanks boys,also I thought that the spacers they pushed too much to the bearings,I will try of a wheel that used standard maxx tires with offset and hex 17mm
Dafni
Dafni's Avatar
03.15.2006, 03:26 AM
Sorry for leading you in the wrong direction :013:
HotnCold
HotnCold's Avatar
03.15.2006, 07:21 AM
1 post in 1500 something posts isnt leading in the wrong direction Daf you were just listing your opinion - this site wouldnt be what it is without your input...
Hows that "Hope and Change" working out for Ya???
virusss
virusss's Avatar
03.15.2006, 07:24 AM
no problem daf, thanks for all...
Batfish
Batfish's Avatar
03.15.2006, 08:22 AM
Heck, Dafni, I don't recall a post from ANY of the experienced people here that didn't recommend putting additional stress on an R/C vehicle. That's what this whole community is about :027:
For example, if you don't want to put stress on an E-Maxx the best thing to do is keep it stock and run cheap 6-cell battery packs, but I don't think anyone here would advise doing that! :003:
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
HotnCold
HotnCold's Avatar
03.15.2006, 08:33 AM
Originally Posted by Batfish
if you don't want to put stress on an E-Maxx the best thing to do is keep it stock and run cheap 6-cell battery packs.:003:
If you dont wanna put stress on it - Keep it in the box - LOL What is life without a little stress......
