ta_man
03.12.2011, 08:45 PM
Originally Posted by mihael View Post
hi there
i am planing to buy the sct mmpro combo for my 1:8er electric buggy
i driving now 2 years the mmpro esc in my 1:8 electric cars with no issue
the new SCT motor, 1415 2400 has a 3,17mm shaft. i dont know if this tiny shaft will break in the 1:8.
i was planing to buy a NEU 1415 1y engine. but this new castle creations combo has all in one. the good esc and a NEU 1415, but hte version with 3,17mm shaft. there is no problem to buy a pinion Modul 1 for 3,17mm. but i dont know if the shaft will break in a 1:8 vehicel
So long as you use mechanical brakes and don't get any stones in the pinion/spur interface, you might be OK. But I think you are lilely to snap the 1/8" shaft clean off if you use it with electric motor brakes on a 1/8th buggy.
The good news is that Castle is supposed to be working on 5MM shaft rotors for the SCT motors, so when you snap your 1/8" shaft, you will be able to buy a 5MM shaft.
03.13.2011, 04:23 AM
I snapped a few hacker 1/8 shafts in 8th scale buggies back in the day. 5mm shaft is mandatory unless you have a slipper setup. Even then, it is just good sense.
outlaw
Castle addicted
outlaw's Avatar
03.13.2011, 04:21 PM
I ran the SCT Pro Kit today in my RC8 to SC10 4WD conversion
Man, this motor is insane !
20 min runtime with about 4800mA
Motor Temp was about 45 degrees no cooling
MMP was about the same.
Gearing was 50/15
But i will stay on my Tenshock based 3S Setup i don't need that much power.
The only thing i don't like on the 1415, is the massiv Rast of the roter.
It is not as much as on the 2650KV CC Motor, but about 80% as on the Tenshock.
I hope to get my "real" SC10 4x4 soon and test the SCT Pro on 3S there ...
kind regards
Mirko
Brushless motors have to be green ....
