nuz69
nuz69's Avatar
03.18.2011, 10:46 AM
Yes, I already have done it ;) But it's not clear, the short current is no dissipated into heat in the ESC but goes to the battery ?
There is another interesting experiment, short the ESC battery input together (without battery) and try to move the car. Above certain speed, the motor brakes.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Pdelcast
Pdelcast's Avatar
03.30.2011, 03:31 PM
That's correct. The ESC could not dissipate all the energy on its own (it would overheat very very quickly,) so it dumps the extra energy onto the bus.
The ESC operates like a boost converter when braking.
http://en.wikipedia.org/wiki/Boost_converter
Take the schematic and substitute the low side mosfets for the switch, the high-side mosfets for the diode, the motor for the inductor, and the battery for the load (on the right side) and that will give you the approximate idea of what's going on.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
