Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Jahay
04.05.2011, 02:15 PM
Hi Brian, i know this is a silly question...
But which alloy tape are you using around your hexs exactly so they fit the 24mm baja hex correctly?
Is it similar to this?
http://cgi.ebay.co.uk/1-Roll-Alumini...#ht_3605wt_809
and obviously it isnt 1mm thick so, would you just do multiple wraps till it fits snug in the hex?
Thanks... and sorry for the silly question... i just dont want to strip my baja hexs
thzero
04.05.2011, 02:18 PM
That's basically the stuff that I was using when I was running 23mm hexes. And yes, couple of wraps and make sure that the fit is snug.
brian015
brian015's Avatar
04.05.2011, 03:39 PM
Exactly - I found my aluminum tape in the ventilation/ductwork aisle at the Home Depot.
And someone else cut a strip of aluminum from their coke can and put it in the hex to fill the space - you could even super glue it to the hex so it stays put when you mount the wheel.
Edit: link to coke can reference
