04.17.2011, 09:39 AM
You ask and you shall receive...Although it's a MRX-3...same basic set up. It's a Revo motor mount
I had a machinist press a fitting inside the hub which in turn eliminated the one way bearing and allows me reverse and motor bakes. Eventually I am going to eliminate the AL bottom battery brace and replace it with carbon fiber...
I am running a 1800kv on 6s and it flies...haven't quite dialed in the esc for a little drag brake, motor brakes yet but working on it. The first time I took it out I almost totaled the car..missed a concrete light stanchion by inches doing 50mph+ This is my first true on road car as it has a learning curve as I only have been running in the dirt
