brian015
brian015's Avatar
05.06.2011, 11:58 AM
Did you check your new top speed? It's still higher than I'd run with something this heavy on an RX8. But you might get away with it if you keep an eye on your temps.
TroubleMan
05.06.2011, 02:51 PM
I was thinking about looking into the AE center diff so i could run the 54 spur i just noticed your post about the size issue i don't want to fight with a dogbone problem while gearing is wopping on me also so that would be heaven sent if i could use one. i wanted to know before i headed out to blow some cash is the ae diff gonna use the same bearings or will i have to order some from vbx vxb i can never remember there name.
brian015
brian015's Avatar
05.06.2011, 04:03 PM
The AE CD uses the same bearings (8x16x5) so that won't be an issue.
TroubleMan
05.06.2011, 07:15 PM
UpdateUpdate!!!! i just horse traded my way into a MMM esc and Tekin just shipped my RX8 i found a complete ae diff and spur 55 bucks so i'm wasting cash at a fast pace but what you think ? ae diff/MMM ?
