06.02.2011, 11:17 PM
I would contact Neu directly and see if you can get a replacement rotor with a longer shaft- there are so many different versions of cans & 2 shaft size options ( 5mm & 8mm ), it may be that the longer shaft version is for a specific purpose vs the regular .75" version you seem to have...
06.03.2011, 03:29 AM
it's not a problem, just put the setscrew on the pinion facing the motor
Jony Nitro
Jony Nitro's Avatar
06.03.2011, 04:25 AM
mm don't think so, it would,nt fit
D8T Brushless
Brushless Baja
SC10 Neu Power
