Hyper-5
The-Hyper One
Hyper-5's Avatar
06.21.2011, 07:46 AM
Originally Posted by BIG-block View Post
Don't do that. You will just kill another motor. If you want to run 6S stick to the CC 2200kv motor and be done with it. With right gearing and decent lipos (you already have a good ESC) you should be pushing 75mph+ easily and have a reliable, fast buggy. 2650kv motor will run hotter and on 6S it will be around it's maximum safe RMP. Not a good thing if you want your motor to last a while.
someone told me that l should run the 2650kV because of the weight of my buggy, it only weighs 7.71lbs 3.5kg with 11.1v and with 22.2v it weighed at 9.1lbs 4.12kg, it wouldn't run as hot as it would with a heavier buggy.
