pinkpanda3310
pinkpanda3310's Avatar
06.23.2011, 10:20 AM
Originally Posted by asheck View Post
Nobody is saying that as your wattage needs increase, you shouldn't go up in voltage. But none of my systems average even 20 amps. Yes there are points that go much higher, but on average between 12-17 . So I'm sure someone can throw the math to it, but assuming a 15amp average draw in my E-revo on 4s, for 45mph, What would really be the gain going to 8s? Is it fair to go by the average amps?
If you don't need to go up in voltage why consider it? Is that revo for racing? Sounds like you have a smooth finger so the gains will be less than if I were to race that setup and move to hv.
Hv setups usually have more grunt right? Is it possible some people learned to be lighter on the trigger as a result?
nuz69
nuz69's Avatar
06.23.2011, 10:24 AM
Hum... No, HV and low Kv have less grunt, because the motor has higher inductance, so it limits amp spikes too.
A LV setup need a smooth finger to spare some mAh and limit amp spikes.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
