josh9mille
josh9mille's Avatar
06.28.2011, 05:33 PM
I just set mine by feel. I adjust for a little rocking motion in the spur. Whenever i need to remove the motor I always remove the the middle gear from the tranny and screw the top back on so i can make sure the mesh is smooth and frictionless. After all that I was still killing the pinions.
Edit. I guess that would make more sense if i said i also loosen the pinion grub so it free spins
