Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
jamesban
08.12.2011, 10:23 PM
I will take it out next week and post some pics. I did not have any extra parts.
jamesban
08.14.2011, 08:47 PM
Tried two different camera and every picture is blurry. I will take it apart tomorrow and post pics of the components laid out in order they are installed. Im pretty sure I have it right per the instructions. Im hoping something is wrong though so i can get it working.
http://s9.photobucket.com/albums/a10...slipperential/
molak
08.14.2011, 08:50 PM
Try a different photographer
pinkpanda3310
pinkpanda3310's Avatar
08.14.2011, 09:52 PM
Did you scuff the pressure plates with sand paper?
jamesban
08.15.2011, 08:35 AM
Yep. I scuffed em. I followed the directions carefully. I will take it apart tonight. One of the pads was slightly deformed and I sanded it a little to get it to pop in place. Maybe its causing an issue?
pinkpanda3310
08.15.2011, 09:25 AM
I wouldn't have thought that would be the issue. If one of the pads is thicker or not seated properly and taking all the pressure that might make a difference. The slippers I have I gave a reasonably good rub with sandpaper so none of the original surface was visible. I did that cause I heard of others saying they couldn't tighten it to the point they were comfortable with (nothing like your scenario though).
slippery slipper
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
slippery slipper - 08.15.2011, 05:04 PM
It is quite hard to see in the video, but it is easy to hear the slippage. Something is very wrong to have this much slip. Scuffing the slipper rings(particularly the one engaging the slipper pads) is important not only for traction, but also because there is a greasy residue on the rings from the manufacturing process.
Also, what grease did you use to grease the adjustment ring threads? I have found that AE black grease works the best - this is also a very important step, as dry or improperly greased threads will not allow you to fully compress the springs (they don't need to be fully compressed usually to work, but they must be compressed a bit to apply enough pressure on the slipper assembly). With the appropriate grease, you should be able to flatten the springs with fairly light pressure.
Aside from that, the only other cause of excess slip(assuming proper assembly) would be oil or grease somewhere on the slip surface(pads or ring). Can you post a couple still pictures of the assembled diff?
