josh9mille
josh9mille's Avatar
08.14.2011, 12:10 AM
Good looking truck! You built a tank for sure! lol. I bet if you used lighter wheels and tires and traded all that aluminum for stock or RPM plastic stuff you would lose weight and not break stuff all the time.
RC-NUT
RC-NUT's Avatar
08.14.2011, 12:48 PM
I think your right. I switched to the big Joes because the rims that I have use a 5 lug system with an aluminum adapter. (If that makes sense) There is no hex to strip or crack. The down side is they are heavy and have a crazy amount of traction so I either melt my slipper or snap the rear dog bones.
I have had good luch with RPM so I may swap a lot of that over.
I'm on the fence about the 1717. Sure it's big and nasty but not as smooth as some others. It's more like a low RPM on/off switch. I'm running a 23/49 and still can't keep the front end down at any speed. The top end isn't that fast but I have a hard time getting there on 4 wheels.
