Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
NickRummy
NickRummy's Avatar
09.14.2011, 09:02 AM
Finally got around to fitting the hub on! Hub on the XL axle with pin through both.
O-ring on the hub to hold pin in place and then with the wheel mounted.
Gave the machinist the go ahead on producing more so I'm getting anxious to see a full set in use!
thzero
09.14.2011, 09:23 AM
Looks very clean. This is what HPI should have designed, even for 17mm wheels, in the first place!
BIG-block
09.15.2011, 11:32 PM
Looks very impressive to say the least. Well done. How hard was the HPI stub axle to drill? Did you have to use a special bit to do the job? Last question. Would you consider making the same thing but in 17mm version for us that are still running 1/8th size? Would be very nice if you did it with similar off set as the stock XL setup has.
