freddy
09.19.2011, 09:01 AM
Thanks for all the suggestions, have kind of messed up the kevlar so realy regretting that i dissasembed this thing.
Tried wrapping it in paper, tape, feeler gauge and everything else i could put my hand on that fit inside the hole, without any success. At this point my best bet is to contact castle for repair.
Btw i really dont understand why they are using so strange srews, like those holding the rear end bell, today i was visiting several hardware shops and i couldent find a single fitting wrench.
Its torx but no torx wrech is fitting
ta_man
09.19.2011, 11:45 AM
Probably use those screws so they can apply sufficient torque to get the screw tight.
It is probably a T6. My T7 doesn't fit at all but the T6 is looser than I would expect. So unless there is a T6.5 , it is probably a T6. I got my small Torx bits an an electrincs store but you can get Torx bits in that size from McMaster-Carr for $1.20. (But being in Norway, I guess McMaster doesn't help you much.)
