freddy
10.01.2011, 04:55 PM
Originally Posted by BIG-block View Post
I think you are way over-geared. With the high speed idler, 1717 motor, 22/44 gearing and on 6S you are geared for over 70mph and that is before you factor in any tire ballooning. Way too much I think and the amp draw from the heavily loaded 1717 motor would be pushing the MMM to and probably beyond it's limits. If you don't believe me enter your setup into the Speed calculator on Scriptasylum.com and you will see. Drop your pinion to 18T and you should be geared for just under 60mph which I think will fix the overheating problem.
Also Deans (even worse fake Deans) connectors don't really cut it in my book when it comes to high draw applications. For a setup like yours the Castle 6.5mm bullets would be much better.
if you check the gearing with the motor kv you will notice it geared for an lower top speed now than with the smaller 1515 motor and stock gearing. also after the rebuild the drivetrain is smother and not least i was only driving on taramc with and bigger motor, lower gearing and smother drivetrain.. the weight increase compared to the stock xl kit is also marginal.
besides im not running 6s but 5s :)
i checked all the connectors and notice that one of the deans on the esc was badly soldered from factory, the wire was barly touching the bar. so i reoldered and took it for an test run and wolla a lot more power and no more hot wires.. but the fun only lasted a few min before esc smoked on me.. also noticed it wasn't any spark when i connected the batteries so i believe the esc was faulty from the previous run.
When i think about it i should have taken a pic of the solder job but i dident now the esc was about to smoke on me.
so the with the 1515 the solder job did an ok job,but with the 1717 i got hot wires. so the 1717 must pull a lot more current through the esc
