Bazzokajoe
01.13.2012, 08:52 AM
i was after some low profile ones... but i guess i could just cut some of the castle ones out :P
nativepaul
nativepaul's Avatar
01.14.2012, 05:54 AM
Naviga have a maximum battery pack weight for boat racing, which includes wire, shrink and connectors I have been close to the limit on several packs despite removing the circuit board, shortening the wires back as much as is feasable, and had to cut the solder buckets off my 6mm connectors which roughly halves the weight of a pair, more weight can come off the female than the male, you need to leave some meat on the back of the male to maintain strength for spring pressure but the female back can be cut foil thick more or less.
Don't cut through the bucket in one go on the male, cut a little, cool it in water, cut a little more, cool again and continue like that until its done, I cut my first couple straight through and although I still left some meat behind the prongs they wouldn't maintain spring pressure, I had got them too hot and annealed the brass making it too soft to spring.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
