Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
03.29.2006, 07:40 AM
About the largest 32P gear you could fit on there would be a 61t. And then you need some crazy small pinions. I used to use 11/61 on my RC10 T2 with M2K's and a 540 6s.
Rusty4Ever
RC-Monster Not Stock
Rusty4Ever's Avatar
03.29.2006, 09:14 AM
:032: Maxx tires are 1.85" taller than M2K's. You're talking spur setup? But after squeeforever inquired & MetalMan answered that the Strobe kit doesn't fit the trans, which is Mod1, nor does the RR Dbl slipper which is the stock 48P.
The 48P HPI/Kim spur gears hold up fine (could've used the CFR metal diff tho, but I'll boil the stock plastics), just the slipper is getting used overtime (carbide balls heat the plates) to protect the trans, likely because of the current locked diff I'm using.
But since Robinson Racing doesn't make the hardened planetary/sun gears anymore, I may keep the locked diff. More straight traction offroad (well, powerslides on turns are fun) & it just tips a little bit turning fast onroad (stresses the suspension). The stock diff probably wouldn't have broke internally if I had the slipper balls changed out beforehand.
The BK ESC .3sec ramp-up throttle delay works well. It'll slowly stand on its rears/wheelie tires from many low speeds on pavement. On grass it wheelies at the slightest touch at most speeds. I have the rear shocks set soft to try to stop the wheelie action.
