Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
brian015
brian015's Avatar
02.19.2012, 08:40 AM
It occurred to me that I could use a sleeve but it would need to be a snug fit to reduce slop.
Yes - but if you could find some 12mm rod or thick walled tube, you could drill a 8mm hole and be in business.
But if you want the full extension of these pro-line adapters I'm using, they are a direct fit on an 8mm axle. I only have to add an insert to them when I make them shorter: http://www.ebay.com/itm/Pro-Line-23m...item2318c5e810
