brian015
brian015's Avatar
02.27.2012, 01:12 PM
Originally Posted by bruce750i View Post
Even though you offset them I still would of used one male and one female. Looks like the negative sides are double long and the positive sides are short. That would make me want to plug them in wrong in a rush.
+1
I use a female bullet on my battery positive, and male bullet on battery negative. I make the positive battery lead an inch or two longer than the negative lead so there's almost no chance of the two connectors shorting out (unless you bent the positive lead 180 degrees). I can then attach batteries in series without a harness.
