Kcaz25
Kcaz25's Avatar
03.11.2012, 05:30 PM
Yeah thanks man!! Well it looks as if they will work great on the front suspension with larger bearing slots(aftermarket knuckles or reamed out slots on stock). That is if the stub axle hole works. and I think it will.
But the traxxas shaft is 130.1mm and I believe it will be about the same because the stub axle will fit deeper into the axle carrier maybe even more than a few millimeters. I say all this to say that I do not think they will work after all.
However mounting the knuckles on the RPM arms is all together a different story and might still work! lol
