anunaki
Smile 03.20.2012, 11:35 PM
It has been possible to revive 'dead' lipos by charging them using nimh/nicad mode on your charger, just use a low charger current and hit it until the voltage rises above ~3.2v per cell ( of 6.4v total for a 2s pack ).
If there are zero volts though I would agree, check each cells individually, sounds more like a broken or cold joint inside the pack..
Damn mann you were right on the money one
of the balance soldering was broken I fixed it with a small peice of solder thanks and
thanks again
