ANGRY-ALIEN
ANGRY-ALIEN's Avatar
06.10.2012, 03:47 PM
You could try the bladders from Revo/Jato GTR shocks, pretty sure they are the same dimensions. Maybe put a little pill of medium/high density foam inside the bladder to stiffen it up?
I forgot about adding a little foam rubber to strengthen the blabber... I know it's not an absolute fix, but it should make a difference...
Originally Posted by chrismechanic View Post
yer +1...if i fill my e-maxx shocks to the brim they will pop if i land a big jump.
the shaft going into the shock pressurizes the inside...liquids wont compress so it pops out the bladder or pops the shock top off.
i know it sucks but leave a bit of air inside them....
chris
I hear that, but it contradicts all the principles of these shocks... if I have bubbles passing through the pistons, I don't see how they will perform well... I will also give this a try and see how it works...
Thanks guys
chrismechanic
06.10.2012, 04:28 PM
well yes i agree...the answer is piggy back shocks...the res will soak up the pressure...but they are more expensive.
chris.
