Kcaz25
Kcaz25's Avatar
08.08.2012, 07:42 PM
Also I could mount the esc higher off the CD mount. I could custom make a center bulk top brace out of my CF stock. People say that some one could land a buggy on you in a race and mess you up! Is it true? Likely? It would allow me to run a larger battery.
-Zack
Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
12.20.2012, 01:05 AM
-Zack
Yes, you can damage the ESC. I had the ESC mounted on the rear of the center diff at the top plate height and there were several close calls.
i've since created a much LOWER mount. The ESC is now about .75" shorter than the front shock tower. So if I happen to land lid first the wing, body, and shock towers will take the abuse and not the ESC.
I don't think the buggies are wide enough to mount the ESC off the center diff though, I only got away with it because I'm using a dual battery tray setup.
I later changed the mounts and lowered the ESC even further.
And here's its current location. Notice how low it is between the two shock towers. Its going to take a direct hit to nail the ESC. And if the hit is like that, it probably wouldn't matter HOW I mounted it.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
