08.12.2012, 07:49 AM
I am going to have to inspect my lipos a little closer. Maybe they are having issues.
The calculator says it was geared for 45 on 6s but it looked like it was doing 30 max which was terribly slow. The motor is running terribly hot and sounds like it is spinning up way too easily. The esc is ice cold too. Which indicated it being undergeared.
My SPIs and badlands are a lot lighter than my baja tires, and the truck is around 14lbs in weight again.
If my charger checks 3 cells in each lipo, then everything should be alright with the lipos right?
They have not really been used much, but have been stores well.
