10.09.2012, 12:45 PM
Could you flip the center diff so you could use normal pinions?
You'd have to cut a new slot in the chassis for clearance or raise the diff.
Ps the cd top plate looks the wrong way around.
You can see in the second pic the cutout in the chassis for spur gear clearance isn't under the spur gear. That center diff is in backwards. That's also why the top plate looks the wrong way around.
lstmuggy- is there any special reason you flipped the diff? Only had long pinions on hand? Good looking truggy, by the way
