11.14.2012, 08:27 PM
I would use a seperate BEC as well to help with some of the stress.
Good catch Cory, I forgot mention that. Doh.
I've seen this posted several times, and it bugs me. Maybe the problem is just semantics, but since this forum is all about correct information I feel the need to clarify this statement so nobody misinterprets it.
Running a separate bec does nothing to "relieve stress" from an esc. Less robust bec's were failing left and right, and when the bec circuit of the esc flames out it ruins the entire esc. So people started using stand alone bec's to keep the internal bec from failing and taking out the entire esc.
I just don't want someone to misunderstand the information and think they could get by with a bigger load (motor) because they use a stand alone bec.
The basis for using a stand alone bec is because if a stand alone bec fails it is a cheap replacement, if the internal bec fails it is expensive because you must replace the entire esc.
This concludes my anal rant of the day.
TL;DR Bec's are cheap insurance not stress relievers
