usmcrc
04.07.2006, 12:15 PM
i tried that for any hour and it didnt work. it doesnt beep after a minute, i timed it. if i turn it on with the throttle in neutral, and then pull the throttle, it beeps once and then the wheels turn. it also wants to randomly go into reverse by itself. i have no idea but this seems almost like it is too difficult. maybe i have the motor leads hooked up incorrectly? what goes where from the mgm 80a to the feigao 8s? do i need the motor not to be hooked up when i am programming the controller? thanks for the help
Gustav
Gustav's Avatar
04.07.2006, 12:50 PM
I thought you hold full throttle then switch on to get into programming mode,that's what the instructions say anyway.
Yes you want the motor connected to the controller,any order will do,if it turns the wrong way just swap over any two wires.
bigair78
04.07.2006, 12:55 PM
I think that is what he did for a full minute. I think what he is saying is after that didn't work he tried it the other way that he mentioned.
Gustav
Gustav's Avatar
04.07.2006, 01:01 PM
Oh,i see,sorry.Well then the next thing to do is check radio,esc may not be seeing full throttle.Check channel is not reversed,EPA is 100% and trim is at zero. Hopefully it's not a fault with the esc where it can't be programed.
usmcrc
04.07.2006, 01:26 PM
so i'm an idiot, the tx throttle was back wards! wow i feel like a jack@ss! havent programmed it yet but i ran it as is and it flies in reverse but not in forward??? i'll get back to ya thanks
tim
