08.26.2013, 07:00 PM
7s Hyperion balance taps I believe are available. I have a 1420 which uses them
You need a 7s charger - you can get away with a 6s balance tap on an 8s battery/charger as the battery lead -/+ act as the other terminals. That's a pretty special config though.
pinkpanda3310
pinkpanda3310's Avatar
08.26.2013, 07:43 PM
So your charger has an 8s balance port? You need to do something like this.
The pic is for 2x 3s, yours will be 1x 7s so the main leads will go straight to the charger. The blank pin on an 8s tap will be at the negative end.
Hope that's what your looking for.
