PBO
RC-Unobtainium
PBO's Avatar
09.10.2013, 04:45 PM
Originally Posted by nastety92 View Post
One set of calipers will be used just for racing to lock the rear wheels.
How would that work? sounds interesting but I don't understand
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
nastety92
09.11.2013, 08:50 AM
There will be a toggle switch inside the truck and that will get turned on so it will lock the rear caliper, then once I go to launch the truck it will release freeing the rear wheels. It's not setup yet, but hopefully it will be soon and I'll have more info.
Nick
Tamiya TRF801Xt-e
nativepaul
nativepaul's Avatar
09.11.2013, 01:35 PM
How would that be useful? Sounds interesting but I don't understand.
When you first mentioned it I was thinking of a drifter, wanting a rear only brake to initiate slides, adding a second calliper could potentially be easier than converting the existing handbrake/Ebrake to hydraulic on some vehicles. But for the drag strip I'm baffled, is it FWD? It could be for burnouts, but I thought trucks were all 4WD or RWD and I don't see the benefit in just burning out the front tyres on a 4WD.
Unless you have a front only brake too and burn out the fronts and rears separately which would be safer than doing all 4 together.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
nastety92
09.11.2013, 02:25 PM
It's going to work more like a line lock would, line lock would normally keep just the front wheels locked but this would keep the rear wheels locked. On these type of trucks it's hard to us to hold boost at the line when we are getting ready to launch. This would help keep the rear planted. This is an all wheel drive vehicle. From what I'm told this is something that the Buick Grand Nationals use on some of there vehicles.
Nick
Tamiya TRF801Xt-e
09.12.2013, 02:13 AM
Get a trans brake. Will be much more effective, and probably less complicated.
