Thomas Porfert
Thomas Porfert's Avatar
10.17.2014, 02:11 PM
This is very surprising to hear. We have seen very few problems with the Sidewinder 8th and 1515B motor. It has actually been one of the most successful releases of a new product in recent history.
What exactly is happening to the ESCs? I see that the most recent one burned on plug-in, but was it run previously? What happened to the other ESCs?
What vehicles are these being run with? Please provide some general setup information including gearing, battery connectors and continuous C rating of the batteries.
The Sidewinder 8th cannot be pushed as hard as a Mamba monster 2. It has a lower amperage rating and as such cannot be geared as aggressively, run in as heavy of vehicles vehicles or be driven as hard compared to the Mamba Monster. Please keep this in mind when choosing the Sidewinder 8th over the Mamba Monster 2.
Thomas Porfert
Tech Support
bigblkblazin
bigblkblazin's Avatar
10.17.2014, 04:25 PM
Model
Slash 4x4
Gearing 18/36
MIP X-duty Axles front and rear
Alloy Arms front and rear
Spectrum DX4C w/ avsc
Traxxas connectors
Nanotech 5600 4s Lipo. 25c-50c
It wasn't run for about 3 weeks . The xl-3 was never used and sold for scrap to the highest bidder.
Thomas Porfert
10.17.2014, 05:54 PM
Well...doing some calculations you are geared for 85 - 100 MPH depending on tire diameter (calculated @ 5" - 6"). That motor is going to be pulling a massive amount of amperage. You are most likely overamping the ESC and/or you have excessive ripple voltage. The continuous C rating on your batteries is far too small for such an extreme setup. We recommend a minimum of a 30C continuous discharge for a normal setup and in an extreme setup you want to have a 40C+ continuous discharge.
With this setup you will continue to burn up ESCs because of the extreme nature of the setup (85+ MPH on a vehicle with horrible aerodynamics). These systems will not be covered by the warranty as the failures are due to an extreme setup and inadequate batteries; we should have never covered the ESC replacements under warranty. We do not warranty any high speed setups. Upgrading to the Mamba Monster could help increase the life expectancy, but those batteries will kill a Mamba Monster and the high speed setup will stress the motor and ESC.
A "safer" speed setup would be to run 6s (with the appropriate discharge) with a larger spur and smaller pinion. The higher voltage will help reduce the amp draw, reducing stress on the ESC, motor and batteries. This would still be a non-warranty setup because of the speed, but the lower amp draw may help increase the life expectancy. Also you should only be running for 1 high speed pass, stopping, letting things cool off before running again.
Thomas Porfert
Tech Support
