sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
04.16.2006, 05:46 PM
this is the areas that I'm saying are machined to thin....yes it probably saves weight....but I think it's more prone to failure....
  Send a message via MSN to sjcrss
Gustav
Gustav's Avatar
04.16.2006, 05:50 PM
Yeah looks like the drive pins (steel?) would eat into those faily quickly in our brushless trucks.Depends what they're made of,'aluminium' is a bit vague.
sjcrss
sjcrss's Avatar
04.16.2006, 06:08 PM
they appear to be just aluminum...but who can tell....I agree with you....with that being so thin...it's prone to failing...here is a little history about how my Ultramaxxed gen II's failed......basicly it was from shifting from 1st to 2nd and back, while under power....and not letting off of the throttle.....this caused the failure in my case.......and that was on gears that had more pin surface contact......and with those appearing to be so thin in that area.....i see a problem ...since alot of the peeps run BL around here.
